Hi all !
Why is not possible to change u-boot environment in CoreELEC 9.2.1 for Odroid N2 ?
fw_printenv and fw_setenv does not works.
/dev/env and /dev/nand_env is not present.
P.S. “clean” installation of CoreELEC to uSD (-ng image).
Hi all !
Odroid devices do not have a bootloader environment.
Sorry for my dumb questions… but…
CoreELEC for Odroid do not have this environment or is a Odroid feature for all OS ?
I read this: https://wiki.odroid.com/odroid-n2/software/partition_table
And I see U-boot environment in this manual.
fw_setenv works (with little problems) in Android on this device.
If is a CoreELEC feature, is possible to add it to next release ?
We use vendor odroid u-boot and there is no /env
partition. I don’t know if Android u-boot differ from our used one. You can use boot.ini
for environment and commands or config.ini
to set environment parameter only.
Is a bad news.
Thanks for answer.
