Hi !
Is possible connect UART on n2 trought 40pin header ? I have cables with dupont connector and im not able connect trought official n2 UART ( small space between pins )
Maybe… It needs to be enabled in the device tree. Not sure weather or not it’s enabled by default in CoreELEC device tree.
https://wiki.odroid.com/odroid-n2/application_note/gpio/uart
Test it and see if it’s enabled
You can use the dupont cables on the small connector, I have done this previously before I got the adaptor.
Oh really, with small amount of force they fit. Thanks.
