Hi,anyone can provide working coreelec firmware for Ugoos AM9 S905x5 TV box?
Or it’s not supported yet.
Not supported yet but will be ready soon.
Okay,do you know is it possible to speed up the process,will it be ready mid july?I can help with beta testing.
Sure, send 100.000 € to the CE devs and priority will be focused only to this device
Nice offer,but this time I’ll skip it.
Why are you in search of firmware for a device you don’t have?
I have it,that’s why I am asking,I want to test coreelec.Also I can test certain things on AM9 box,so if you’re interested,write what you want to know and I’ll try to test it and include in video.
BTW,is it okay to post my YT channel and AM9 review video here when it will be ready?
Just asking,I don’t know local rules.
Did you take it from AliXP?! The only seller there wants nearly 300 Bucks
Only 300€? Guy from the top requested 100 000€ for coreelec firmware, so few hundrend euros for tv box is nothing
I have my ways,I didn’t get it from ali,but you still have time to ask something and I can test it,but keep in mind,I am not gonna do scratch test,bend test or drop test,only software related tests.
Yeah, scratch test would be fine. Curious if the the official Kodi would play H266 out of box on the AM9. So I could use it with android version of kodi to the point CE will be released for the X5. Still have the x5M Version, which has such a good pic quality in compare to my ATV4K.
Edit: But why is H266 not mentioned on the packaging? They wrote it especially on their Webseite
WOW… thank you for the test. Then Kodi should play it too.
I was able to play some street fighter 3rd strike on AM9 and it run quite good:
GOW 2 was only 30 fps,so currently unplayable.
Android 14 has some flaws with older apk files,but i found way to fix it.
If for whatever reason you are unable to install apk file which was made for earlier android version and you need it
on your device really bad,as for me I was unable
to install antutu 5.7 I got error every time,there is a solution
enable usb debugging in developer settings and turn off google protect
download adb,put it to your PC root folder something like C:\adb and apk file in same folder,then run cmd with administrator rights and copy those commands
cd C:\adb
adb kill-server
adb start-server
adb tcpip 5555
adb connect 192.168.1.123 (enter ip of your tv box) (allow debugging on android tv box)
adb devices -l (shows if you are connected to your tv box)
adb install --bypass-low-target-sdk-block apkfilename.apk
and apk file will be installed,hope I have explained it properly =)
Here is antutu 5.7 Benchmark result.
