@smg04
HelIo, I asking for help.
I installed the latest version(131 for v19 Matrix).
But my initial setup on client side(Kodi)won’t start.
When i try to pair y device - it doesn’t work either(Kodi log):
2022-01-06 22:59:01.663 T:8837 ERROR <CSettingGroup>: unknown setting type "hidden" of "addon_version"
2022-01-06 22:59:01.664 T:8837 ERROR <CSettingGroup>: unable to create new setting "addon_version"
2022-01-06 22:59:01.664 T:8837 ERROR <CSettingGroup>: unknown setting type "hidden" of "last_run"
2022-01-06 22:59:01.664 T:8837 ERROR <CSettingGroup>: unable to create new setting "last_run"
2022-01-06 22:59:01.664 T:8837 ERROR <CSettingGroup>: unknown setting type "hidden" of "launchscript_conf"
2022-01-06 22:59:01.664 T:8837 ERROR <CSettingGroup>: unable to create new setting "launchscript_conf"
2022-01-06 22:59:08.940 T:4729 ERROR <CSettingGroup>: unknown setting type "hidden" of "addon_version"
2022-01-06 22:59:08.940 T:4729 ERROR <CSettingGroup>: unable to create new setting "addon_version"
2022-01-06 22:59:08.940 T:4729 ERROR <CSettingGroup>: unknown setting type "hidden" of "last_run"
2022-01-06 22:59:08.940 T:4729 ERROR <CSettingGroup>: unable to create new setting "last_run"
2022-01-06 22:59:08.940 T:4729 ERROR <CSettingGroup>: unknown setting type "hidden" of "launchscript_conf"
2022-01-06 22:59:08.940 T:4729 ERROR <CSettingGroup>: unable to create new setting "launchscript_conf"
Lunalog is not generated
But through SSH (by moonlight pair command) the pin code is generated and visible on the host side (NVIDIA GAMESTREAM) and the connection is established:
CoreELEC:~/.kodi/addons/script.luna/bin # moonlight pair
Connect to 192.168.2.145...
Generating certificate...done
Please enter the following PIN on the target PC: 7031
Succesfully paired
the games are visible:
CoreELEC:~/.kodi/addons/script.luna/bin # moonlight list
1. RESIDENT EVIL 2
2. It Takes Two
BUT in Kodi i cant run any game, they are not presented in LUNA
Thanks for your reply. It helped. After starting the addon again it displayed my games.
After lauchning a game from kodi the game launch on the pc, Kodi display the intro animation but then nothing
If you exit and re-enter the game on Kodi, sound and control appear, but the screen remains black @smg04
Attaching moonlight and Kodi logs logfile (4.7 KB) kodi.log (8.4 KB)
What Matrix version are you running? Latest Luna doesn’t work with nightly CoreELEC. Latest update in libamcodec broke moonlight-embedded, so the version i’ll post right now works only on nightly builds.
On top of that, you either have unstable connection or your Luna settings are very wrong. Reset your Luna settings to default values, then try and set it up again.
The dev branch has been updated, the last build (1.1.1-matrix.143) was built on it. I usually commit on main once it has been tested and working. I would like to make a package bump but is there a way to only allow it to be installed on versions of CoreELEC 19.4-Matrix_rc1 and higher?
it just dont activate HDR on TV, colors are not that wrong, so i say theres a conversion hapenning somewhere… (besides HDR, its working ok, maybe dropping a few frames, but very usable)
I don’t think there’s anything to do as frames are sent to the decoder as-is. Maybe you have some HDR->SDR function enabled in CoreELEC settings or that’s some default but since I don’t have anything to test it with, wontfix.
Have just updated CoreELEC to the latest RC2 build last night and also applied your 143 release.
However, I’m still getting a black screen whenever I try to launch anything.
I did try rolling back to release 131 incase I misinterpreted that only the nightly releases were affected and not RC2, but that version is just the same.
