Hi!
Hope this is the right thread to ask.
Problem:
Both Kodi and CoreElec Settings can be secured with a PIN.
However using the PIN exposes all the settings, with little granularity available under Kodi Settings, for instance.
What I want:
I would like to put a tag (WiFi- Net Settings) on one of the popular customizable skins like Aeon Nox or Arctic Zephyr 2 for CE 9.2.2, such that only the Network settings section ( for configuring WiFi, Bluetooth, Ethernet) is exposed.
This ensures that anyone at home can quickly configure the network without compromising the hard won myriad other settings.
Questions:
How can this be accomplished?
Is there a general (easy) process without much coding to isolate other sections too, eg, first finding the complete path to such sections, then using a skin tag to click onto?
Maybe some advancedsettings.xml configuration, or just putting the path definition inside the Skin?
