The addons have not been update. Addons will be updated in the 8.95.5 release.
In the mean time If you would like to test updated versions of these addons, I can compile them for you to test, so you can download and use the install from .zip option manually install them.
However, I can’t say how quickly I’ll be able to get to doing so.
No, the addons are not specific to a device. Every one of the amlogic based devices can use addons compiled for the others.
In fact the only reason for the different builds is because each device requires either a different boot loader, different video drivers or slightly different configuration then the others. Besides that the builds are pretty much the same. Basically just enough differences between devices that we can’t release one build for them all.
