Today i’ve upgraded to the 9.2.5 for X96mini. Sinces then when i play a video, the screen increases by like 20%. If I click to bring up the bottom bar menu (pause, skip, settings, subs etc…) it’s cut off
When I stop the video, it switches back to the main Kodi screen and for a moment it’s too big then flickers and shrinks back to proper size.
I went to the video calibration screen, it’s set to correct for my display TV to 1280x720 and it’s exactly how it should be sized as i previosly calibrated.
Any ideas? Kodi menus is fine… only video playback is wrong.
Playing with the input configuration on my television I got some improvement although still a part of the OSD was out and not visible. After experimenting with changing the refresh rate and recalibrating the display seems that I have solved the problem.
I ran into this same problem. After the update I would start a video and my screen would cut out and then it was overscan. If I stopped the video, it would blank out and be back to normal in the interface. I found out that the update must have enabled adjust display refresh rate in videos under the player settings. I turned this off and it fixed both my overscan and my screen cutting out when starting and stopping playback.
