VIM3 fan control
Sorry, I edit my post
Ran the script for a few hours while watching last night. Did not notice any sudden fan action. It stayed on those values most of the time:
CPU Temperatur “= “44”.”9°C
GPU Temperatur “= “46”.”3°C
CPU Temperatur “= “45”.”0°C
GPU Temperatur “= “47”.”3°C
CPU Temperatur “= “44”.”8°C
GPU Temperatur “= “46”.”1°C
Hello, i have installed the 3705 fan on khadas vim3 with coreelec OS, but it not work. How can i active it?
also bought the 3705 FAN… but its not working…
seems i2c-tools are not installed…
i can activate the Fan on Kodi… how this works without i2c-tools?
i want to use this on emuelec as well… :slight_smile:
i2c-tools are part of system-tools addon.
Maybe this could help too: service.coreelec.settings/hardware.py at coreelec-19 · CoreELEC/service.coreelec.settings · GitHub
seems it writes some values to /sys/class/fan nodes.
Ahh. CoolMaybe this works for emuelec… j
Yes it works…
Same problem here with my VIM3 and VIM4… On both boards, the fan does not work with CE-NO. Is there a fix for this? With CE-ne, the fan works… the device settings even expose an option to set behavior… only CE-no does not work…
