Where can I see your PR to main branch? I have to disable OTA updates while feature is merged and added into rc3 or 19.2
Regarding time gap: it just works like that. You change settings, go out of settings and you get info for reboot. I didn’t saw anyone complain for this. And you do that only once
Just disable automatic update in CE settings.
The option should be included in tomorrow nightly.
After update please remove once the dtb.xml to update the file from devel build to nightly/rc build.
Like by:
mount -o rw,remount /flash
rm /flash/dtb.xml
sync
reboot
