I am confused of installing CoreELEC 19.4. on Vim3L eMMC. I found zipped image of CoreELEC 9.2.5 for Vim3L, I uploaded it to Vim3L by USB cable, it was autoupdated to 9.2.8, it works fine.
I tried to install CoreELEC 19.4 by uploading update to .update directory, I was unable to boot. I prepared fresh install on SD card, it works. But I would like to use eMMC, I prefer better performance. Is there any image or guide how can I do it?
I tried to use ceemmc, there is no SD card and here is output
CoreELEC:~ # ceemmc -v
Starting CoreELEC eMMC installation tool...
eMMC size: 0x0003a3e00000 [16GB]
Original partition table:
[mmcblk0p01] bootloader offset 0x000000000000, size 0x000000400000 [4 MB], code
[mmcblk0p02] reserved offset 0x000002400000, size 0x000004000000 [64 MB], unkn
[mmcblk0p03] env offset 0x000006c00000, size 0x000000800000 [8 MB], code
[mmcblk0p04] logo offset 0x000007c00000, size 0x000000800000 [8 MB], code
[mmcblk0p05] coreelec offset 0x000008c00000, size 0x000020000000 [512 MB], code
[mmcblk0p06] storage offset 0x000029400000, size 0x00037aa00000 [14250 MB], data
No CoreELEC installation found on eMMC
Install in dual boot mode, CoreELEC and Android on eMMC
Use CoreELEC data from
Install in single boot mode not possible!
No DT partition was found
Please choose one option? [1/2]: ^C
Thank you
m
