Hi all, ive just noticed that while playing a video i can no longer adjust the volume or mute?.
I swear this worked ok before.
It works if you stop the video?
… for this reason I do not use audio passthrough in S912
If you have passthrough enabled, you can’t control volume from Kodi. You can only do it from your AVR.
I must be lucky then as sometimes it works sometimes it does not lol, but at least i know now thanks.
It works when passthrough is not enabled for a video or if you’re not playing anything at all.
