Hello everyone,
first post, so I hope I’m in the right sub and all.
I bought a used Wetek Hub to use as my home entertainment player. Strictly playback from my NAS (1080p) & a few streaming addons, so a not too demanding task.
I setup Coreelec on a microsd (a bit older Sandisk, so probably not the best one around) and added my library (roughly (!) 50 TV shows & 300 movies), switched to Estuary Mod V2 skin and configured it.
Playback seems to work fine (not thoroughly tested), but when scrolling through the library I get freezes of about 30 seconds every minutes and had a few freezes where only a hard reboot helped. That was all while scrolling through the library. Then I noticed the hub warmed up quite a bit.
Therefore I ask myself if the Hub is not cut out to perform on a level which I would need, overheats and therefore freezes?
Setup is:
Hub connected via lan, using NFS to stream my files from a Synology Diskstation, HDMI to receiverv.
Any thoughts?
Greets & thanks in advance for any help
