Hello there,
Just moved to Coreelec on my Wetek Hub, the installed worked great. I copied the settings files that I used on all my Kodi installed (two others Kodi running on Archlinux)
advancedsettings.xml
sources.xml
passwords.xml
mediasources.xml
I normally have no issue, but now Coreelec boot up as normal, however, no database is available and looks like a first install. It takes few minutes for the database too actually load up and being displayed. Once there all the files etc can be accessed.
Kodi log on pastebin => https://pastebin.com/rr5nABfP
Thank you for looking at the thread
