But when recommending a supported box, which is not a bad idea, it is also a good idea to provide the bigger picture in terms of real total cost, warranties and potential hardware issues (with the N2 at least).
It should also be remembered that there are a great many users with the cheap boxes that are perfectly happy, otherwise such discussions would never come up in the first place.
In terms of the prices being mentioned from ameridroid, potential extras for an ‘equivalent’ setup to an average box would mean WiFi and Bluetooth adapters, eMMC adapter (and additional cost to go for the 4Gb model).
Then there is the consideration of the shipping fee, which when added to the hardware cost is then subject to 20% import duties on top.
Then there is the 30 day warranty (which if I remember can be extended for yet more cost) and the consideration about the process that you would have to go through to return it abroad and the associated costs.
@PatrickJB should at least be shown as much as the picture as possible.
He seems used to the luxury of being able to return items with zero fuss to certain more convenient sites, so other options would deny that kind of luxury.
There is of course a UK based Odroid retailer, which when you add everything up probably makes more sense overall, if potentially a little more expensive at the outset (shame about their 3 month warranty though).
When the N2 works well, it is certainly the best thing out there in the AMLogic spectrum and if hardkernel has admitted production mistakes that have caused hardware issues and specifically stated that they had resolved them for good, then I would have one myself.
If @PatrickJB is looking for value against performance, the C4 does seem to be a reasonable looking halfway house for the performance that it offers and so far does not seem to have resulted in unnecessary hardware faults. All of the other elements associated with a purchase are the same though.
In terms of the Beelink GT-King being a consideration, it seems that some love it and others have issues. Supposed use of cheaper, inferior components, poor heat dissipation and their often lousy support may be downsides to some, so perhaps a potential gamble.
We can definitely agree on setting up from scratch and as I have said test as you go along to spot anything that may be an otherwise unknown cause of issues and I can see the wisdom of not skimping on a box/sbc IF a great deal of money has been spent on the TV it is going to output to.
My own cheap crap of S905X2 and S912 boxes work wonderfully, even in the summer and to date, out of around 100 or so devices that I have owned since the early days of TV sticks, only 3 have really suffered from really derogative overheating, two of which came from a brand name that had supposed good support and quality products, Zidoo.
