My Beelink MINI MXIII II S905X was previously working and I was able to see multiple resolutions.
After being prompted to update to 9.2.4.2 I have no audio and only a single resolution(720p).
Also the screen stays blank during boot.
The Beelink is connected to an amp via HDMI. I have tried the different Audio output options, previously it was using passthrough to the amp via HDMI.
I saw another post suggesting to run “dispinfo”, here’s the output of that. http://ix.io/2B9m
Thanks. All components were turned on, the Beelink input on the amp was also selected.
The boot time seems much longer than it used to be, 30 seconds or so.
I just tried again after pulling the power, and the behaviour is the same.
Multiple reboots later it now has identified my Amp and TV. Both Audio and Video are back working as expected. http://ix.io/2BeT
Is there there some way to preserve/retain this configuration? In case the Amp and or TV are on different inputs during boot up?
