Why I personally gave up on Coreelec
Used to have an Odroid N2 in 2020 running Coreelec on a NUC. The NUC died and I drifted to Android Boxes.
I have just bought a Homatics Box R plus intending to run Coreelec. I have an Amazon Fire Cube 3rd Gen which I’m beginning to dislike for lots of reasons.
This is what I’ve tried so far.
Installed ng on a powered 120GB SSD. The OS would load but not play.
Installed ng on a 32GB USB drive and this would install and I was able to use Coreelec , however if I powered off the Homatics Box I would get a grey screen and no CE.
Reinstalled and as long as I kept the box powered all was good. Tried different versions of CE from ne to no but the ng was the only one that would work.
I then tried to pair my Sofabaton x1s with Kodi. This proved to be extremely difficult and eventually I resorted to using a mouse and keyboard.
As this was intended for use by myself and wife ,not having the use of the universal remote ,was not going to suit my wife. I have this working well on the Fire Cube
Eventually I choose to use Kodi 21.2 preinstalled on the Homatics Box with the sofabaton controlling HTS. I will eventually retire the Cube but at the moment I have BBC iplayer installed from my Amazon UK account using a DNS, which my wife would not be happy to lose.
I feel that I should have stuck with CE but using Android TV and projectivity launcher ,which allows me to boot straight into Kodi, makes things easier for she who must be obeyed.
It took me a while to go through all of this, so not user friendly. How you get round this so a lot more can try CE I’m not sure.
Anyway thanks for to everyone who supplied the various posts I used install CE. Perhaps what’s missing for me was an updated installation guide for my box.
Geoff
Wiki is not enough…
Anyway, hope you will find a peace without CE.
Takeaways:
Homatics isn’t the “best device for CoreELEC”
Sofabaton not working is Sofabaton’s problem
NG is EOL
BBC iplayer is 3rd party to CoreELEC
FireTV Cube Gen3 just gained the ability to run CoreELEC so before you retire it and downgrade to Homatics maybe look at putting CE on it.
This isn’t going to solve your issues with CE though since they’re external and user issues.
Enjoy your vanilla, poor, no audio pass through, no auto resolution, no dolby vision profile 7 FEL, basic Android experience with Kodi though.
Best of Luck
Tried to boot to CE again from the USB after powering off the Homatics and same problem grey screen.
Will look into CE on the Fire Cube 3rd gen. Got to be better than my experiences with the Homatics.
Would like to be able to use CE but it has to be user friendly for my wife!!
CE is user friendly !
My wife is able to use the remote control.
But, I use Odroid N2, no android box like homatics or amazon cube etc.
I think CE is simply the wrong software/os for You.
