Wifi is not working on Mecool M8S PRO W
I installed CoreELEC-Amlogic.arm-9.0.3-Generic.img.gz to an SD by means of LibreELEC.USB-SD.Creator.Win32, the system has started without problems, but in the connections part I do not see the list of wifi networks :frowning:
I have tried with gxl_p212_2g.dtb and gxl_p281_2g.dtb which are the ones I started with.
Help please :woozy_face:
Your device has an unsupported WiFi driver S9082C, your only option is run old version of LE, use a USB wifi adapter or use Ethernet.
