Dear All,
I bought Android box Tesla x300 (s905x2,2gb ram), and usb wifi adapter netis wf2190 (rtl8812au), i have installed on SD card coreelec 9.2.1. Its possible that in coreelec 9.2.1 is old driver for the wifi chipset ? Or the usb 3.0 port work as usb 2.0? I have problem that i cant connect to the wifi (some input/output error), or im disconnected from the wifi with wifi status failured, when im connected i have lower speeds (aproximaty 180mbits) as when i connect the usb driver to pc (aproximaty 450mbits) which ones is on the same place as the box. Thanks you
