hello, i have the mecool m8s pro l box, the wifi works fine but if i reboot or power of then back on the wifi isn’t connected says failure. if i click on it, it will connect right away. is there a way to have it stay connected? using this image CoreELEC-S912.arm-8.95.6-S912
any chance i can get help with this issue? i went to the thread as advised, when i asked a question seems like they keep deleting it as its not related to the posted that was provided.
sir i a not trying to hijack anything. i have read through the suggested thread but i am not understanding what i need to do to fix it. if i have broke some rules it was not intended that way and i am sorry for doing so.
sir, when i used winscp to ftp into my box i didn’t see that folder. i guess i don’t understand how do i located that folder, as i only see the .config folder?
sorry i guess these are all dumb questions, as this is easy to you.
i noticed that when my box reboots i am disconnected from wifi, must i apply this fix to 9.0.3? even time i try to connect then i get a input error. i must delete the wifi reboot boot then log in every time?
@bumerc @Portisch
Does this method still work for WiFi adding the sleep.d dir and adding the code into the file as I have tried it on latest build but I still get failure on WiFi when I resume from suspend
