Dose CoreELEC for Odroid C2 has a plugin like WiringPI? I have python scripts to control the Audiophonics SPC II power module. The scripts send GPIO status that the module reads.
I can’t find is there is a Python support that I could convert the scripts for the C2.
Here is an example of the RPi script I run on LE for RPi:
shutdown
#!/usr/bin/python
# "Audiophonics shutdown script"
# " Openelec Version"
# "Shutdown: GPIO13 = in, low"
# BootOK: GPIO22 = out, high "
import sys
sys.path.append('/storage/.kodi/addons/virtual.rpi-tools/lib')
import RPi.GPIO as GPIO
import time
import subprocess
GPIO.setmode (GPIO.BCM)
GPIO.setup (13, GPIO.IN)
GPIO.setup ( 22, GPIO.OUT)
GPIO.output (22, GPIO.HIGH)
PinValueT0 = False
while True:
#grab the current button state
PinValue1 = GPIO.input (13)
# check to see if button pushed
if PinValue1!= PinValueT0 and PinValue1 == True:
subprocess.call ("shutdown -h now", shell = True, stdout = subprocess.PIPE, stderr = subprocess.PIPE)
time.sleep (1)
Thanks,
AlleyCat
