I’ve tried to install CE 19.1 on this my new box X99 Max-922 based on S922X chipset. It is very similar to X88 King, and i can install CE using dtb supplied for X88 King. Everything seems to work, but the network is unusable; ethernet only seems stable at 100M and wifi does not perform great. If I try to use gigabit ethernet it becomes unstable and I have to unplug the cable. It is on v.20210109 firmware. Is there anything I can do with the original firmware to try and get CE 19 to work properly? My old S912 with CE 9.2 worked perfectly on the network; I wouldn’t want to have to trash this new S922X. Any help is appreciated. Thanks
