Xiaomi Box S 3rd Gen as a Dual-boot CE Box
Yes you’re right, it is enabled in the Android, but what i understand the wireless sdio interface cause the kernel panic and without the panic i get no working WiFi/BL, it’s like the sdio conflicting with the usb, and when the sdio wifi is disabled the wifi usb interface work and i got working WiFi/BL, maybe i’m wrong but that’s why i hope someone correct this problem, especially for future updates
Ok, I’m confused. You are saying that with disabled SDIO node everything works?
Yes that is exactly what i experienced, but i’m talking for just disabling the sdio@fe088000 noting else.
Seems your expectations are way to high. Remember: this is not commercial product and this forum is not 24/7 helpdesk. As you can see it relies mostly on user to user help. Which still means you ask and wait for answer from somebody. And if no one is in a mood to write anything back you can’t do anything.
And this “Asked again and again, never got an answer” doesn’t help much to get an answer. Actually when I read such posts I usually skip them. Unless there is something regarding which really interests me.
And it is really “whatever” from now on. Good luck.
Is there any chance of getting eMMC install supported or is it going to be USB only?
eMMC would be nice if possible.
Anyone having issue where rebooting keeps taking you to GTV instead of booting into CE? If I install CE from scratch, it works.
And if you do again reboot from Android does it go to CE?
No need fresh install.
Yes… re-did fresh CE install and now it’s holding (booting into CE as expected) when I power off/boot up, or reboot from GTV side.
