Well as the title says, i have a Z69 4K with 3GB ram and S905X. However i cant get 4K to work. Ive followed the recomended settings, but it still dont work. Ive played arround with the CoreELEC settings aswell with no luck.
When i try to look at the whitelist it only shows up to 1080p.
The TV is a Samsung 48" 4K LED TV, i can get the serial number if you need it. But other devices run 4K without a problem on it. It dont run throug anything. Just straight into the TV.
Just checked and dont seem like it have it. The model is ue48ju6575 from 2015. Strange thing is i have a little S905X HDMI stick running 4K YouTube for me. So dont see why CoreELEC shouldnt work.
If it doesn’t support HDMI 2.0, it could be why it’s not listing the 4K resolution as an option.
Can you run dispinfo in SSH and post the link?
Also, pinging @cdu13a. HDMI 1.4 spec should still be able to handle 8-bit 4K@30P and 4K@60P@4:2:0
So I looked at the dispinfo output and two things stand out edid_parsing failed, and the TV is only recognized as being capable of hdmi 1.4. despite also detecting a HDMI 2.0a feature(HDR).
Out of curiosity which resolutions do you see listed in kodi?
Also try a different HDMI port. Some TV’s despite being listed as hdmi 2.0, have a mix of hdmi 2.0 and 1.4 ports. Some TV’s especially earlier HDMI 2.0 also had HDMI ports set for compatibility with HDMI 1.4, and settings for port needs to be changed to enable full HDMI 2.0 capability.
My TV have four HDMI ports, and have tried three of them without any change. But i guess i can try the last one out. Regarding the settings for HDMI 2.0 i dont really know where it would be hidden
Very strange, think i found something. Have activated something for HDMI 1 and are going to try it out now after my box have restarted. Well this time something deffently happned. Now my TV just dont detect a signal.
