this is the dispinfo output:
http://ix.io/3Uu0
is there some error displayed? can’t interpret the output.
CoreELEC Display Information...
------------ /etc/os-release ------------
NAME="CoreELEC"
VERSION="19.4-Matrix"
ID="coreelec"
VERSION_ID="19.4"
PRETTY_NAME="CoreELEC (official): 19.4-Matrix"
HOME_URL="https://coreelec.org"
BUG_REPORT_URL="https://github.com/CoreELEC/CoreELEC"
BUILD_ID="d9d4343999a9953ecc2733d9ab26a6ecaac76849"
LIBREELEC_ARCH="Amlogic-ng.arm"
LIBREELEC_BUILD="official"
LIBREELEC_PROJECT="Amlogic-ce"
COREELEC_ARCH="Amlogic-ng.arm"
COREELEC_BUILD="official"
COREELEC_PROJECT="Amlogic-ce"
COREELEC_DEVICE="Amlogic-ng"
------------ /proc/device-tree/coreelec-dt-id ------------
g12b_s922x_odroid_n2plus
------------ /proc/device-tree/le-dt-id ------------ Not Found!
------------ /proc/cmdline ------------
BOOT_IMAGE=kernel.img boot=UUID=0503-5410 disk=UUID=c20c9dcf-3a75-494c-bc19-f77ba72bede8 console=ttyS0,115200 console=tty0 no_console_suspend keymap=us remotewakeup=0x23dc4db2 decode_type=0 remotewakeupmask=0xffffffff vout=1080p24hz,en logo=osd0,loaded,0x3d800000 frac_rate_policy=1 native_4k_gui=0 hdr_policy=1 quiet systemd.show_status=auto
------------ /sys/devices/virtual/amhdmitx/amhdmitx0/edid ------------
Rx Manufacturer Name: SNY
Rx Product Code: 050b
Rx Serial Number: 01010101
Rx Product Name: Q95A
Manufacture Week: 44
Manufacture Year: 2017
Physcial size(mm): 1210 x 680
EDID Version: 1.3
EDID block number: 0x1
blk0 chksum: 0xa7
Source Physical Address[a.b.c.d]: 4.1.0.0
native Mode f3, VIC (native 95):
ColorDeepSupport b8
95 16 31 4 19 5 20 32 33 34 93 94 98 100 3 18 95 94 93 98 352 353 357 358
Audio {format, channel, freq, cce}
{1, 7, 7f, 7}
{2, 5, 7, 50}
{7, 5, 1f, c0}
{10, 7, 6, 0}
{12, 7, 54, 0}
{11, 7, 7e, 1}
{9, 5, 2, 0}
Speaker Allocation: 5f
Vendor: 0xc03 ( HDMI device)
MaxTMDSClock1 300 MHz
vLatency: Invalid/Unknown
aLatency: Invalid/Unknown
i_vLatency: Invalid/Unknown
i_aLatency: Invalid/Unknown
ColorMetry: 0x3
SCDC: 0
RR_Cap: 0
LTE_340M_Scramble: 0
HDR/13 DeepColor
checkvalue: 0xa7980000
------------ /sys/devices/virtual/amhdmitx/amhdmitx0/edid_parsing ------------
ok
------------ /sys/devices/virtual/amhdmitx/amhdmitx0/rawedid ------------
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
------------ /sys/devices/virtual/amhdmitx/amhdmitx0/config ------------
cur_VIC: 93
cur_video_param->VIC=93
VIC: 93 3840x2160p24hz
Colour depth: 10-bit
Colourspace: YUV444
Colour range: default
EOTF: SDR
YCC colour range: limited
Colourimetry: BT.709
PLL clock: 0xdb00049a, Vid clock div 0x000b0000
audio config: on
audio on/off: on
audio source: I2S
audio type: L-PCM
audio channel num: 6 channels
audio sample rate: 48kHz
audio sample size: MAX
3D config: off
------------ /sys/devices/virtual/amhdmitx/amhdmitx0/dc_cap ------------
420,8bit
444,12bit
444,10bit
444,8bit
422,12bit
422,10bit
422,8bit
rgb,12bit
rgb,10bit
rgb,8bit
------------ /sys/devices/virtual/amhdmitx/amhdmitx0/dv_cap ------------
The Rx don't support DolbyVision
------------ /sys/devices/virtual/amhdmitx/amhdmitx0/attr ------------
------------ /sys/devices/virtual/amhdmitx/amhdmitx0/disp_cap ------------
480p60hz
576p50hz
720p60hz
1080i60hz
1080p60hz
720p50hz
1080i50hz
1080p30hz
1080p50hz
1080p25hz
1080p24hz
2160p30hz*
2160p25hz
2160p24hz
smpte24hz
smpte30hz
smpte50hz
smpte60hz
2160p50hz
2160p60hz
640x480p60hz
------------ /sys/devices/virtual/amhdmitx/amhdmitx0/vesa_cap ------------
640x480p60hz
------------ /flash/vesa.enable ------------ Unset by user!
------------ /sys/devices/virtual/amhdmitx/amhdmitx0/custom_mode ------------ Not Found!
------------ /sys/devices/virtual/amhdmitx/amhdmitx0/preferred_mode ------------
1080p60hz
------------ /sys/devices/virtual/amhdmitx/amhdmitx0/hdr_cap ------------
HDR10Plus Supported: 0
HDR Static Metadata:
Supported EOTF:
Traditional SDR: 1
Traditional HDR: 0
SMPTE ST 2084: 1
Hybrid Log-Gamma: 1
Supported SMD type1: 1
Luminance Data
Max: 0
Avg: 0
Min: 0
HDR Dynamic Metadata:
colorimetry_data: 0
------------ /sys/module/am_vecm/parameters/hdr_mode ------------
0
------------ /sys/module/am_vecm/parameters/sdr_mode ------------
0
------------ /sys/module/am_vecm/parameters/video_process_status ------------
1,2
------------ /sys/module/am_vecm/parameters/hdr_policy ------------
1
------------ /sys/class/display/vinfo ------------
current vinfo:
mode: 0
frac: 1
width: 3840
height: 2160
field_height: 2160
aspect_ratio_num: 16
aspect_ratio_den: 9
sync_duration_num: 2997
sync_duration_den: 125
screen_real_width: 1210
screen_real_height: 680
htotal: 5500
vtotal: 2250
fr_adj_type: 4
video_clk: 297000000
viu_color_fmt: 2
viu_mux: 2
3d_info: 0
master_display_info:
present_flag 0
features 0x0
primaries 0x0, 0x0
0x0, 0x0
0x0, 0x0
white_point 0x0, 0x0
luminance 0, 0
hdr_static_info:
hdr_support 13
lumi_max 0
lumi_avg 0
lumi_min 0
hdr_dynamic_info:
metadata_version: 0
support_flags: 0
optional_fields:
metadata_version: 0
support_flags: 0
optional_fields:
metadata_version: 0
support_flags: 0
optional_fields:
metadata_version: 0
support_flags: 0
optional_fields:
hdr10+:
ieeeoui: 0
application_version: 0
------------ kodi display settings ------------
coreelec.amlogic.limit8bit: false
coreelec.amlogic.force422: false
coreelec.amlogic.deinterlacing:
coreelec.amlogic.noisereduction: false
coreelec.amlogic.hdr2sdr: false
coreelec.amlogic.sdr2hdr: false
videoplayer.adjustrefreshrate: 2
videoplayer.useamcodec: true
videoplayer.useamcodech264: 0
videoplayer.useamcodecmpeg2: 0
videoplayer.useamcodecmpeg4: 800
videoplayer.usedisplayasclock: false
videoscreen.whitelist:
lookandfeel.skin: skin.estuary
------------ /storage/.kodi/userdata/disp_cap ------------ Unset by user!
------------ /storage/.kodi/userdata/disp_add ------------ Unset by user!
------------ /flash/resolution.ini ------------
# WARNING DO NOT MODIFY THIS FILE! ALL CHANGES WILL BE LOST!
kernel_hdmimode=1080p24hz
frac_rate_policy=1
native_4k_gui=0
allfmt_names=2160p60hz 2160p50hz 2160p30hz 2160p25hz 2160p24hz smpte24hz smpte25hz smpte30hz smpte50hz smpte60hz 1080p25hz 1080p30hz 1080p50hz 1080p60hz 1080p24hz 1080p120hz 1080i60hz 1080i50hz 720p60hz 720p50hz 480p60hz 480i60hz 576p50hz 576i50hz 480p60hz_4x3 480i60hz_4x3 576p50hz_4x3 576i50hz_4x3 2160p60hz420 smpte60hz420 2160p50hz420 smpte50hz420 2560x1080p50hz 2560x1080p60hz 640x480p60hz 800x480p60hz 800x600p60hz 852x480p60hz 854x480p60hz 1024x600p60hz 1024x768p60hz 1152x864p75hz 1280x768p60hz 1280x800p60hz 1280x960p60hz 1280x1024p60hz 1360x768p60hz 1366x768p60hz 1400x1050p60hz 1440x900p60hz 1440x2560p60hz 1600x900p60hz 1600x1200p60hz 1680x1050p60hz 1920x1200p60hz 2048x1080p24hz 2160x1200p90hz 2560x1600p60hz 3440x1440p60hz 2400x1200p90hz invalid
------------ /flash/boot.ini ------------
ODROIDN2-UBOOT-CONFIG
# boot.ini
# WARNING DO NOT MODIFY THIS FILE! ALL CHANGES WILL BE LOST WITH THE NEXT UPDATE!
# Set your own settings in config.ini
setenv bootlabel "CoreELEC"
setenv remotewakeup "0x23dc4db2"
setenv decode_type "0"
setenv remotewakeupmask "0xffffffff"
setenv coreelec "quiet"
setenv vout "1080p60hz"
setenv frac_rate_policy "0"
setenv native_4k_gui "0"
setenv rootopt "BOOT_IMAGE=kernel.img boot=UUID=0503-5410 disk=UUID=c20c9dcf-3a75-494c-bc19-f77ba72bede8"
setenv consoleopt "console=ttyS0,115200 console=tty0 no_console_suspend"
setenv dtb_mem_addr 0x1000000
setenv uenv_addr 0x13000000
if load mmc ${mmc_dev}:1 ${uenv_addr} resolution.ini; then env import -t ${uenv_addr} $filesize; fi
if test "${allfmt_names}" != ""; then for name in ${allfmt_names}; do if test "${kernel_hdmimode}" = ${name}; then setenv vout ${name}; fi; done; fi
if load mmc ${mmc_dev}:1 ${uenv_addr} config.ini; then env import -t ${uenv_addr} $filesize; fi
if test "${cec_func_config}" != ""; then setenv cec "hdmitx=cec${cec_func_config}"; fi
if test "${gpiopower}" != ""; then setenv gpiopower "gpiopower=${gpiopower}"; fi
setenv irsetup "remotewakeup=${remotewakeup} decode_type=${decode_type} remotewakeupmask=${remotewakeupmask}"
if test "${usbopts}" != ""; then setenv usbopts "usbopts=${usbopts}"; fi
if test "${usbpower}" != ""; then setenv usbpower "enable_system_power=${usbpower}"; fi
if test "${max_freq_a53}" != ""; then setenv max_freq_a53 "max_freq_a53=${max_freq_a53}"; fi
if test "${max_freq_a73}" != ""; then setenv max_freq_a73 "max_freq_a73=${max_freq_a73}"; fi
if test "${modeline}" != ""; then setenv cmode "modeline=${modeline}"; fi
if test "${wol}" != ""; then setenv wol "enable_wol=${wol}"; fi
if test "${keymap}" != ""; then setenv consoleopt "${consoleopt} keymap=${keymap}"; fi
setenv displayopt "vout=${vout},en logo=osd0,loaded,0x3d800000 frac_rate_policy=${frac_rate_policy} native_4k_gui=${native_4k_gui} hdr_policy=1"
setenv initargs "${rootopt} ${consoleopt} ${max_freq_a53} ${max_freq_a73} ${wol} ${cec} ${irsetup} ${usbpower} ${gpiopower} ${usbopts} ${cmode}"
setenv bootargs "${initargs} ${displayopt} ${coreelec}"
load mmc ${mmc_dev}:1 ${loadaddr} kernel.img
load mmc ${mmc_dev}:1 ${dtb_mem_addr} dtb.img
bootm start
booti ${loadaddr} - ${dtb_mem_addr}
bootm
------------ /flash/config.ini ------------
# config.ini
# Console Setup
# consoleopt='console=ttyS0,115200 console=tty0 no_console_suspend'
# CPU Frequency Control
# WARNING!!! WARNING!!! WARNING!!!
# Before changing anything here please read the wiki entry at:
# https://wiki.odroid.com/odroid-n2/application_note/software/set_cpu_freq
# max_freq_a73='1800'
# max_freq_a53='1896'
# HDMI CEC Control
# Set by CoreELEC Settings
# cec_func_config='7f'
# HDMI CEC OSD Name
cec_osd_name='CoreELEC'
# IR setup
# Setup a custom keycode to wake the N2/C4 from suspend or poweroff
# You can stop kodi and eventlircd and use "ir-keytable -u" to obtain a compatible u-boot
# IR keycode
# This setting will require a injected bl301 blob.
# remotewakeup='0x31ce4db2'
# decode_type can be one of the following:
# NEC='0x0', DUOKAN='0x1', TOSHIBA='0x2', RCA='0x3', RC5='0x4', RC6A='0x5', NEC_TOSHIBA_2IN1='0x6',
# NEC_RCA_2IN1='0x7', RCMM='0x8', NEC_RC5_2IN1='0x9', NEC_RC5_2IN1='0xa', RC6='0xb'
# decode_type='0x0' # NEC
# remote power key mask:
# Some IR protocols implement a toggle bit, this can be ignored by the "and" mask:
# RC5='0x37ff', RC6='0x1effff', RC6A='0xffff7fff'
# remotewakeupmask='0xffffffff'
# WOL Setting, 0=off/1=on
# wol=1
# Power Off and Wake Up using GPIO Key Button
# Valid options for Odroid N2/C4 are 476,477,478,479,480,481,483,484,485,486,487,488,489,490,491,492
# Valid option for Khadas VIM3 is 503
# gpiopower=476 # (pin 16 of J2 header)
# USB specific options
# usbopts='usb-xhci.tablesize=2'
# USB Power Control
# usbpower=0
# HDMI custom mode
# You can use this setting to set a custom video mode
# modeline "horpixels,verpixels,pixel_clock,hor_freq,ver_freq,hdisp,hsyncstart,hsyncend,htotal,vdisp,
# vsyncstart,vsyncend,vtotal,hsync_polarity,vsync_polarity,progress_mode"
# Example for 1920x1080p@60hz
# modeline='1920,1080,148500,67500,60,1920,2008,2052,2200,1080,1084,1088,1125,1,1,1'
# VOUT mode
# You can use this setting to set a specific video mode at boot.
# vout='1080p60hz'
# Fractional Refresh Rate
# You can use this setting to set a fractional refresh rate. So for example if vout mode it set to
# 1080p60hz then setting this to 1 will make the refresh rate switch to 59.97hz instead of the modes
# default of 60hz. In this example setting it to 0 will keep the modes default of 60hz.
# frac_rate_policy='0'
# Busybox console keyboard layout
keymap='us'
# CoreELEC Developer Options
# Valid options are: textmode debugging progress nofsck nosplash noram overlay quiet ssh
# coreelec='quiet'
------------ /storage/.config/autostart.sh ------------ Unset by user!
