I running nightly 9.1-2019-09-06 at Beelink GT1 mini S905X2 4G/64G.
2.4Ghz reciver not woking at USB 2.0, worked perfect at usb 3.0. I can’t boot CE from USB 2.0, worked ok at usb3.0.
The USB2.0 still not work after updated 2019-09-10 .
What receiver are you talking about?
2.4GH Logitech or beelink receiver both can’t work. work fine on USB3.0.
When use U Disk boot from USB2.0, it also can’t boot.
Then it’s more likely that your USB 2.0 ports are bad than CE not working right.
I restart boot to andirod, the USB 2.0 is fine.
Boot into CE and run lsusb from SSH.
And also dmesg | paste
Then post the output here.
I reinstalled CoreELEC-Amlogic-ng.arm-9.2-nightly_20190914-Generic.img,there two gtp for s905x2-4G,this is used the no“1”。
CoreELEC:~ # > dmesg | grep -i usb
[ 0.608066@3] usbcore: registered new interface driver usbserial_generic
[ 0.608107@3] usbserial: USB Serial support registered for generic
[ 0.611650@1] usbcore: registered new interface driver usbhid
[ 0.611653@1] usbhid: USB HID core driver
[ 0.660700@0] amlogic-new-usb2-v2 ffe09000.usb2phy: USB2 phy probe:phy_mem:0xffe09000, iomap phy_base:0xffffff80083fa000
[ 0.661042@0] amlogic-new-usb3-v2 ffe09080.usb3phy: USB3 phy probe:phy_mem:0xffe09080, iomap phy_base:0xffffff80083fe080
[ 1.414270@1] usbcore: registered new interface driver snd-usb-audio
[ 1.679054@1] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 1.679064@1] usb: xhci: determined sg_tablesize: 4294967295
[ 1.679450@1] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.679453@1] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.679456@1] usb usb1: Product: xHCI Host Controller
[ 1.679458@1] usb usb1: Manufacturer: Linux 4.9.190 xhci-hcd
[ 1.679460@1] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 1.679864@1] hub 1-0:1.0: USB hub found
[ 1.680115@1] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 1.680122@1] usb: xhci: determined sg_tablesize: 4294967295
[ 1.680157@1] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.680220@1] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.680223@1] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.680226@1] usb usb2: Product: xHCI Host Controller
[ 1.680229@1] usb usb2: Manufacturer: Linux 4.9.190 xhci-hcd
[ 1.680231@1] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 1.680528@1] hub 2-0:1.0: USB hub found
[ 1.681290@1] dwc_otg: usb0: type: 2 speed: 0, config: 0, dma: 0, id: 0, phy: ffe09000, ctrl: 0
[ 2.007771@1] usb 1-1: new full-speed USB device number 2 using xhci-hcd
[ 2.151685@1] usb 1-1: config 1 has an invalid interface number: 4 but max is 3
[ 2.151692@1] usb 1-1: config 1 has no interface number 2
[ 2.154268@1] usb 1-1: New USB device found, idVendor=248a, idProduct=871f
[ 2.154272@1] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.154275@1] usb 1-1: Product: 2.4G Wireless Air Mouse
[ 2.154278@1] usb 1-1: Manufacturer: www.videocon.com
[ 2.154280@1] usb 1-1: SerialNumber: Belon SmartMouse
[ 2.184675@1] input: www.videocon.com 2.4G Wireless Air Mouse as /devices/platform/ff500000.dwc3/xhci-hcd.0.auto/usb1/1-1/1-1:1.3/0003:248A:871F.0001/input/input2
[ 2.244143@1] hid-generic 0003:248A:871F.0001: input,hiddev0,hidraw0: USB HID v1.01 Keyboard [www.videocon.com 2.4G Wireless Air Mouse] on usb-xhci-hcd.0.auto-1/input3
[ 2.247978@1] input: www.videocon.com 2.4G Wireless Air Mouse as /devices/platform/ff500000.dwc3/xhci-hcd.0.auto/usb1/1-1/1-1:1.4/0003:248A:871F.0002/input/input3
[ 2.248234@1] hid-generic 0003:248A:871F.0002: input,hidraw1: USB HID v1.01 Mouse [www.videocon.com 2.4G Wireless Air Mouse] on usb-xhci-hcd.0.auto-1/input4
[ 70.927969@3] usb 1-1: USB disconnect, device number 2
[ 100.779770@3] usb 1-1: new full-speed USB device number 3 using xhci-hcd
[ 100.923486@3] usb 1-1: config 1 has an invalid interface number: 4 but max is 3
[ 100.923494@3] usb 1-1: config 1 has no interface number 2
[ 100.926525@3] usb 1-1: New USB device found, idVendor=248a, idProduct=871f
[ 100.926530@3] usb 1-1: New USB device stringCoreELEC:~ # [ 0.451372@2] usbcore: registered new interface driver usbfs
sh: missing ]
I changed gtp.img to g12a_s905x2_4g_1gbit.dtb,restart. Should i use which one ? Has 1gbit or not?
By the way, the “power” button also not working .
CoreELEC:~ # lsusb
CoreELEC:~ # dmesg | grep -i usb
[ 0.463161@2] usbcore: registered new interface driver usbfs
[ 0.463204@2] usbcore: registered new interface driver hub
[ 0.463266@2] usbcore: registered new device driver usb
[ 0.605952@1] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.605959@1] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.606394@1] usbcore: registered new interface driver cdc_acm
[ 0.606398@1] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 0.606460@1] usbcore: registered new interface driver usb-storage
[ 0.606580@1] usbcore: registered new interface driver usbserial
[ 0.606633@1] usbcore: registered new interface driver usbserial_generic
[ 0.606680@1] usbserial: USB Serial support registered for generic
[ 0.610212@3] usbcore: registered new interface driver usbhid
[ 0.610215@3] usbhid: USB HID core driver
[ 0.659278@0] amlogic-new-usb2-v2 ffe09000.usb2phy: USB2 phy probe:phy_mem:0xffe09000, iomap phy_base:0xffffff80083fa000
[ 0.659657@0] amlogic-new-usb3-v2 ffe09080.usb3phy: USB3 phy probe:phy_mem:0xffe09080, iomap phy_base:0xffffff80083fe080
[ 1.414503@3] usbcore: registered new interface driver snd-usb-audio
[ 1.678764@3] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 1.678773@3] usb: xhci: determined sg_tablesize: 4294967295
[ 1.679161@3] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.679164@3] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.679167@3] usb usb1: Product: xHCI Host Controller
[ 1.679170@3] usb usb1: Manufacturer: Linux 4.9.190 xhci-hcd
[ 1.679172@3] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 1.679562@3] hub 1-0:1.0: USB hub found
[ 1.679818@3] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 1.679825@3] usb: xhci: determined sg_tablesize: 4294967295
[ 1.679860@3] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.679921@3] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.679924@3] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.679927@3] usb usb2: Product: xHCI Host Controller
[ 1.679929@3] usb usb2: Manufacturer: Linux 4.9.190 xhci-hcd
[ 1.679932@3] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 1.680224@3] hub 2-0:1.0: USB hub found
[ 1.680944@3] dwc_otg: usb0: type: 2 speed: 0, config: 0, dma: 0, id: 0, phy: ffe09000, ctrl: 0
[ 2.011493@3] usb 1-1: new full-speed USB device number 2 using xhci-hcd
[ 2.155385@3] usb 1-1: config 1 has an invalid interface number: 4 but max is 3
[ 2.155391@3] usb 1-1: config 1 has no interface number 2
[ 2.157939@3] usb 1-1: New USB device found, idVendor=248a, idProduct=871f
[ 2.157942@3] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.157945@3] usb 1-1: Product: 2.4G Wireless Air Mouse
[ 2.157948@3] usb 1-1: Manufacturer: www.videocon.com
[ 2.157950@3] usb 1-1: SerialNumber: Belon SmartMouse
[ 2.192446@3] input: www.videocon.com 2.4G Wireless Air Mouse as /devices/platform/ff500000.dwc3/xhci-hcd.0.auto/usb1/1-1/1-1:1.3/0003:248A:871F.0001/input/input2
[ 2.251899@3] hid-generic 0003:248A:871F.0001: input,hiddev0,hidraw0: USB HID v1.01 Keyboard [www.videocon.com 2.4G Wireless Air Mouse] on usb-xhci-hcd.0.auto-1/input3
[ 2.255494@3] input: www.videocon.com 2.4G Wireless Air Mouse as /devices/platform/ff500000.dwc3/xhci-hcd.0.auto/usb1/1-1/1-1:1.4/0003:248A:871F.0002/input/input3
[ 2.255720@3] hid-generic 0003:248A:871F.0002: input,hidraw1: USB HID v1.01 Mouse [www.videocon.com 2.4G Wireless Air Mouse] on usb-xhci-hcd.0.auto-1/input4
[ 100.704331@3] usb 1-1: USB disconnect, device number 2
Hi brucecao.
Not sure how you made out, likely not good… However follow-up is at Beelink GT1 Mini & CoreELEC, No USBv2 Port
