21.3-Omega on Minix U22-XJ keeps crashing now
CoreELEC (official): 21.3-Omega (Amlogic-ng.arm)
Machine model: Minix U22-XJ
CoreELEC dt-id: g12b_s922x_minix_u22xj
Linux version: 4.9.269 (portisch@ubuntu) #1 Tue Nov 4 18:23:37 CET 2025
Kodi compiled: 2025-11-04 17:37:48 +0000
log-2026-09-20-11.11.14-FAILED.zip (194.1 KB)
I am currently running 21.3-Omega (Amlogic-ng.arm) but recently I have been having lots of failures on booting up. I want to upgrade to a more recent version of CoreELEC, but my Hardware is no longer fully supported.
Which box would you recommend?
Your hardware is fully supported.
you can update to CoreElec NO v22. i have u22-xj running CE NO 22.
Alright, thanks. Which of the several nightly versions should I download? The generic one?
yes, and rename dtb as usual.
