when i select boot to internal, nothing happens.
known issue or function not enabled?
Thx,
Ralph
Thx,
Ralph
Just try reboot right after ‘Reboot to Internal’
This will be fixed in 8.90.2.
okay with selecting reboot it works
Good to know!
Do we have a date yet 8.90.2?
Imminent, any day now . . .
It’s just been released, let us know your feedback
It does work with the default skin, but not as a shortcut from other skins. No big deal because it’s easy enough to add a 2 line script (to reset after calling rebootfromnand ), and point the shortcut at that instead
Here 24 hours running smooth, remote control back to normal more vivid colors
I have a small problem with AXN channel audio some small cuts
in 3 minutes sometimes in 5 minutes
nothing else that hinders, very good every day better the coreelec!
Here in Brazil We are already announcing your work.
Soon we will open an exclusive topic coreelec
