yes all enabled and checked kodi log for change display framerate and it shows the right one but have microjudder. so maybe someting different is causing it.
will go back to 90.3 now.
would be good to know if there are new problems and where. I have a lot of “Frame rate : 25.000 FPS/ Original frame rate : 23.976”-Files (but x265). Do you have a clou, @anon88919003 ?
I did not check .04 yet, but in 8.90.3 there are no problems with such files (after whitelisting of course). I check this with testfiles from time to time.
well, if some logs are needed, let me know which ones. a test build with latest kodi version to compare if its kodi related would be also nice but i guess 8.90.5 will be soon available, so lets see.
the microjudder is not all the time like when i watch it on my TV.
