In the previous version sometimes the remote keys stopped working once I was using TVH. Since 8.90.5 my USB remote works as always but without the volume buttons. The mute button works, I can see the red symbol in the right corner but sound remains. Did I miss something? I’m on a S905 K1 Plus box.
In case let me know how I can provide logs for this issue.
I just installed it. Went into the “Global->Audio” and set volume up/volume down. Keypress is detected by the addon but after saving these buttons still don’t work.
Sounds like you have passthrough enabled.
When Audio is passed through to your receiver (or even TV) unprocessed by the box, you can’t control the volume from Kodi.
It does not work at all. I restarted and it works again. I was once talking with @anon88919003 or @afl1 about it. Back then it was told to me that it is a known TVH bug.
Try making a backup copy of the /storage/.kodi/userdata/keymaps/gen.xml file created by the Keymap Editor addon. Then you only need to copy it back into /storage/.kodi/userdata/keymaps to restore your setup. If this happens frequently, maybe add it to /.config/autostart.sh
I don’t think the keymaps get lost. Cause I can see it mapped even if it does not work.
I can tell you one thing about this issue, it appears after a restart and once it is there it does not stop. Could be after another restart I’m lucky again.
Mecool KI pro - 8.95.0 I have noticed the volume controls failing on a trio of occasions now. They seem to reappear and work ok if I reboot. Passthrough is disabled.
When they fail it’s impossible to control the volume through either the RF remote or the IR. The volume control bar that would normally appear doesn’t appear. The on screen volume controls also don’t work. But a reboot reinstates everything.
