Username is kodi. Password can be anything.
Well, I do something wrong, I guess. I changed both password rows to kodi, and use kodi as a username, and password in my advancedsettings.
mysql
192.168.1.191
3307
kodi
kodi
kodi_video
mysql
192.168.1.191
3307
kodi
kodi
kodi_music
But after restart, when I go to Video to set the content of my folders (as I usually do when adding a new advancedsettings), when I select a content type, it is not âstoredâ. I can set the content again, like it was never done/confirmed, hence no database is created
Well, I donât know what is the process but when I was creating this addon I exported current database and then imported after new sql server. And everything run as before.
Check kodi log if connection to sql server is even made.
Hi! Problem solved. I ran an extended debug log on the windows kodi client, noticed that a certain media object seemed to problematic. I removed the folder, and everything has been working great since (4 days). Really nice to have solved the issue, but a bit concerning that a movie/folder can make kodi âcrashâ in the whole network.
good to hear. Maybe you could wrote a bit more. I am guessing some special encoding, which wasnt setuped correctly on other parts (mysql / kodi / disc) of system?
Actually, I didnât think that it would solve it, it was just me playing around (desperetaly), so I didnât make any documentation. I will however check if I can find more infoâŚ
I could be wrong here, but I think it was many many lines of this for a certain mkv-file:
DEBUG: CThumbExtractor::DoWork - trying to extract filestream details from video file rar://nfs
