9.0.3 Discussion
I guess it isn’t strictly needed.
But for me…
Because the internal isn’t as good on every device.
Because one device is in a cupboard.
Because another device is behind a tv.
Because it means I can use the same setup on every device (CE or other).
Because I can stick a receiver next to my tv’s ir receiver.
It’s working on 2019.07.02 - do you mean that one, or the next to be released?
After update 9.0.3 not work pvr iptv simple client … not playing tv stream , only radio stream
Next release.
@Mireki1975
  1. No
  2. Yes
@flappy81
It should be good, we didn’t have any complaints in the nightly/test threads.
2GB should be ok, and the C2 eMMC should work. But you will need a new PSU.
Just trying to figure out if this is an issue on my end. When this update was released, there was an update to inputstream adaptive on my 9.0.2 box, but afaict, with same version number. This “update” seems to have been pushed to the 9.0.2 channel. I say “update”, because the version number is the same as mid June update. Anyway, since update, inputstream is broken. How can I install the version I was using until today? Or do I have to switch to 9.0.3? Thank you.
Nice, going to update my N2 to 9.0.3 shortly here. Probably stay on the stable releases now, excellent.
Which version did you run, which number ?
Here you have all versions you can try.
But, update to 9.0.3 would be a better solution…
I can’t confirm, tv works fine for me.
Thanks. Odroid UK seems to ship it with PSU though :slightly_smiling_face:
@TheCoolest
Thanks for clarify , is it blocked from the Hardware side that 3D FullHD is not playable?
I’m also interested in this function if possible. Mean won’t have to burn to a BDR to play in my Bluray player.
Hmm, I didnt hit freezes on my C2’s before (9.0.1, 9.0.2). Must check, if I have enabled deinterlacing or not, but I think its enabled. Finally I have also DVB-T2 signal at home so I could do TV signal tests also (MPEG2 on DVBT and H265 on DVBT2 on my country)
I’ve come back on 9.0.1. 0n 9.0.2 or 9.0.3 it works one day… And after playback bug occurs with tvheadend, video over samba and other stream… But if i see corelec stats, much C2 are on 9.0.2 and 9.0.3… So i suppose, there are problem somewhere in my kodi conf but where…
Thank you for that link. It was 2.3.22.1. I reinstalled it from scratch, rebooted. Still confused how it happened, but it works now. Thanks again :slight_smile:
I’ll try to install it again, because I came back to 9.0.2
Is there a reason why under 9.0.3 stable list, the x96mini only has the 2G option ( but not the 1G one)?
Our database is not a complete list of every device and every configuration, its dependant on users telling us what works so we can add it to the list.
On release 9.0.3 for my Mecool M8S Pro L I have almost constant stuttering and dropped frames on stored TV shows in 576p (Cheers) that did not occur with 9.0.2. Doesn’t seem to affect 1080p. Will investigate further tonight and grab a log.
Without logs then we don’t know what the problem is and can’t help.
Running S905 (Q-Box). After automatic upgrade DTD no longer correct and 3D movies stop every few seconds. I’ll have to manually roll back :frowning:
