About two weeks ago, I purchased an eMMC card for my C2. I booted the MicroSD to Raspbian and used dd to write the CoreElec 9.2.2 image to the eMMC.
I then removed the MicroSD and booted CoreElec straight from the eMMC. I restored a copy of the /storage/ directory from a backup I took and everything has been working great.
So, I’ve just downloaded the CoreELEC-Amlogic.arm-9.2.3.tar upgrade file, ssh copied it to /storage/.update/ directory and restarted the device.
It then failed with:
*** Error in mount_storage: mount_common: Could not mount UUID=
### Starting debugging shell for boot step: mount_storage… type exit to quit
After I rebooted it, it loads into Kodi, but but then fails within a few seconds. The device seems to power down and not respond.
This process has always worked in the past when upgrading the MicroSD. Should it work for upgrading when running from the eMMC?
Thanks for any tips.
