A device with model number s905w cannot successfully boot up the system
I have a device with CPU model S905W that cannot be started using the gxl_p281_2g device tree file in the system. Of course, I have also tried several similar dtb files, but none of them have successfully started on the device.
I extracted the dtb file of the device from other systems, which can be used for installation on armbian and Android systems and has been verified to support normal device startup. However, using the extracted dtb file for the CoreELEC system did not take effect.
May I ask if it is possible to convert the contents of this dtb file into content that can be recognized by the CoreELEC system? If EMMC support can be smoothly written, it will be even more perfect. Thank you very much!
download_dtb:天翼云盘 珍藏美好生活 家庭云|网盘|文件备份|资源分享
Model: Nongshang Cloud S11
CPU:S905W
Memory: 2GB
Storage: 32GB
Network card: 100M
HDMI: Supports
Infrared: Supports
WIFI: not supported
Compare the differences and adjust CE dts.
