I have a Nexbox A95X-B7N, Amlogic S905X, 2GB RAM with CoreELEC installed to internal. I have been using this device for quite some time, first with LibreELEC and now CoreELEC for a year and a half, without any problems. But since last week the device won’t start. I get to see the Nexbox logo, and sometimes the CoreELEC logo for one second. And then the image goes black and it looks like the device turns off (but the blue LED light stays on). I then tried different monitors and cables, but that did not solve the problem. I try to find out the IP address of the device via the terminal, but the device is not in the network. So I can’t access the device via SSH either.
Then I tried to put a new build on an SD card with the correct device tree, put the SD card in the device and then hold down the reset button with a toothpick and plugged in the power cable. I get to see the Nexbox logo, but then I get a black screen again. I have tried the latest stable and nightly versions, but both have black screens. I then tried some older builds such as 9.2.7 and 9.2.6. That got me a bit further. After the Nexbox logo I saw the CoreELEC logo. Then I saw the message ‘Partition resizing in progress’, and then ‘Rebooting in … seconds’. After rebooting I saw the CoreELEC logo for a second, and then black screen again. I still can’t access the device via SSH.
I feel like I’ve tried everything, but nothing works. It’s also so strange because before it just worked for a year and a half without any problems. Is my device just broken or is there something else I could try?
Remove the # from this line in config.ini (root of the SD Card) and see if the issue persists:
# VOUT mode
# You can use this setting to set a specific video mode at boot.
vout='1080p60hz'
