yes i did try other port in the BOX and in the PC no result, the pc can detect the USB but as unknow USB device, but the tools no
Unknown USB device can sometimes indicate a driver issue.
Can you get access to another PC of a family member or friend to try?
the only other pc i have is a mac ox, do you have the driver?
The driver is installed during the installation of the USB Burning Tool, so something might not have installed correctly.
But without the ability to try another PC, the cable needs to be ruled out, so if you can get your hands on another one …
USB method:
Have you tried with box Powersupply connected?
Have you tried to remove/deinstall the device from Windows device manager before starting the tool?
SD method:
see https://www.cnx-software.com/2016/11/19/how-to-create-a-bootable-recovery-sd-card-for-amlogic-tv-boxes/
Try it with image and check after creation you have three files on the SDcard (IMG,UBOOT,INI). If yes, try to recover the box, maybe it works for you.
Just do as Portisch told you wayback and now rho-bot as well.
More precisely using windows.
Using BurnCard Maker (Not to be confused with USB burning tool)
find someone with a windows xp machine. It will work.
i finally made thank you guy thank you, i will post the method ASAP
Good news.
Post the solution on the other 2 forums too as it will make life easier for others in the future.
Please, post the solution.
hello,
here is the method i did make to unbrick my A95X MAX
the website is noobs.tech
I’m sure that this will come in handy and good on you for taking the time to write it up.
thanks @Compent
Hi. Can someone help me by explain how I connect my FT232RL adapter UART to this motherboard A95X V81?
This have 6 pin, and there is no information on motherboard. Im trying to unbrick my android tv box, but I cant find this info
