Add SSH mmc-utils
would it be possible to add this tool to CoreElec? Good for emmc diagnostics for example for Odroid.
https://git.kernel.org/pub/scm/utils/mmc/mmc-utils.git/about/
Can you try if this one works on CE19?
vim3 ~ $ ./mmc
Usage:
        mmc extcsd read <device>
                Print extcsd data from <device>.
        mmc writeprotect boot get <device>
                Print the boot partitions write protect status for <device>.
        mmc writeprotect boot set <device> [<number>]
                Set the boot partition write protect status for <device>.
                If <number> is passed (0 or 1), only protect that particular
                eMMC boot partition, otherwise protect both. It will be
                write-protected until the next boot.
It is working fine on latest nightly.
I may be doing something wrong, but it doesn’t work for me. For example, I put the file in the videos folder. And I’ll enter
cd videos
./mmc
What is the procedure?
chmod 755 mmc
./mmc
oh such nonsense. thanks a lot. It works
Works also for CE 9.2.
Maybe it could be added as addon package? Or into system-tools? Its kinda usefull check emmc health status through it.
Can you copy/paste the usage of this tool?
example
mmc extcsd read /dev/mmcblk0
EXT_CSD_DEVICE_LIFE_TIME_EST should be related to reserved blocks, so that value could be usefull for user…
I have send PR to LibreELEC. And after merging there it will be available to CoreELEC too.
