I am running the latest version of CoreELEC on a Venz V10 in my car. I am running it for movies only, for the kids. The movies are stored on a USB flash drive.
When I add movies I remove the USB from the Venz/Car and add movies from my computer, at home.
Is there anyway I can add the movies to the library and get the iMDB data directly onto the USB flash memory from my computer, so it is all there when I put back in the car? So not having to do those operations on the Venz unit in the car. For several reasons it is a real hazzle doing it in the car.
That will add a nfo file and the artwork for each film
So you end up with
MyFilm.MKV
MyFilm.nfo
for each film it only adds about 2M Per film
Rerun the same process but at the last step “Overwrite Old” select NO this will just add tags for new content and should only take less that a minute.
