Adding nfs mounted files to library fails
I have a CoreElec running on N2, which loads it’s files over nfs. The nfs server runs on an OpenSuse Tumbleweedbox. This has worked for some years, and before the N2, Kodi was used on an Raspberry PI with the same setup.
But since some time, it sees the nfs share, but when adding the files to the libraries the process halts, and CoreElec becomes completely unresponsive from within the graphical interface. A ssh-shell stays alive though.
There are a few systems (all opensuse, mostly Leap) that do nfs mounts to that same nfs server on the Tumbleweed system. These mounts too are dead from this point on. The only way I found so far to get these mount back is to reboot the server system.
The server runs NFS v4.
I have made a new install, on another N2 box, with CoreElec 20.1, (CoreELEC-Amlogic-ng.arm-20.1-Nexus-Odroid_N2.img.gz), but it shows the same behaviour.
Any ideas what might be happening here?
