No CoreELEC Kodi addons can currently be installed or updated because addons.coreelec.org is down. Please fix!
Should be fixed. And addons are at https://addons.coreelec.org/leia/
No working Addons currently. Kodi repository currently down… Any idea when it will be fixed?
It should work. Little slow but working.
If not can you post kodi debug log?
From which country it doesn’t work?
i can confirm, it works now. What was the main Problem?
Nothing was changed in last 15 minutes. The last change was done 2 hours ago when first reported.
What did you changed ? before 2h…
Nginx restarted…
Topic can be closed. Everything works well
