Adjust refresh rate messes up lipsync?
Hello, my system is Odroid N2 → Denon AVC-X3800H -AVR → TCL 98R754 -TV.
When using static refresh rate (eg 23,798 for movies or 50 for tv-shows) lipsync is ok for all files that match the refresh rate set in Kodi settings. If I use adjust refresh rate and white listing, lipsyc for videos that need to use different refresh rate than default, is out of sync. Why is this happening, and is there a way to fix this?
Oh it seems that adding delay about 3s after changing refresh rate fixes this. For some reason my system is not able to get lipsync ok without that delay.
Sorry didn´t go into very big measures on troubleshooting this at first. Even kodi wiki is not that clear about that why this “Delay after change of refresh rate” -setting is used. Gladly I found that it fixed my problem after testing different times with it. Hope this helps someone else with same problem.
