Hi All,
Whilst I am using Kodi normally on Android and Windows, I recently bought the Beelink GT-King which came withan SD card containing Kodi for CoreElec.
How can I add the advancedsettings.xml file and where since I can’t find a /.kodi/userdata directory, only .img files, SYSTEM file, etc.
Beelink starts automatically Kodi on CoreElec and when I look at the directories of the SD card from Android I can’t see the /.kodi/userdata directory.
@pat:
To see those files/directories boot CoreElec and go to Settings (cogwheel on top row) then choose “Media” icon. There first select Expert at the bottom, and then under General enable “Show hidden files and directories” and “Allow file renaming and deletion”.
After that you can use Kodi file manager to see and manipulate all files/directories in Storage partition.
Hi thanks for the above, I can get to this location and have saved an advancedsettings.xml file to allow extra media but this still doesn’t seem to get picked up kodi on coreelec? Has anyone got any hints on doing this’ll i really want to do is have the following added this is a copy of my file;
i have a strange issue with this file, if i set the buffer mode to 1 videos just won’t play anymore.
i want to buffer because some uhd with hdr sutter like hell when played from NAS source. from usb source they play just fine. that’s why i want some buffer to have more smooth playback.
i’m using the xml example from kodi wiki.
my box is a tanix tx3 mini with amlogic s905w and 2GB of ram.
hope you can give some advice
