Hi everyone,
I currently have a Minix Neo U1 and looking for an inexpensive (>$100) box that is capable of 4K HDR10.
I am looking for something that is readily available on Amazon.ca (links).
I am also wondering if there are any problems with easily removing the microSd card from the Minix and just popping it into a new device without the need to flash a new card.
Thanks for any advice.
Any Amlogic box sold today can do it. Except S905 and S905W.
Great! I was looking at this one on Amazon, but what device tree would I use?
Where you buy your box is up to you.
We do not advise where you shop.
Use the search function .
If you want to play high bitrate 4k over the LAN, look for a box that has gigabit ethernet or factor in a cheap usb nic.
Ok. Sorry about that. Thanks for the info. I found out what I needed. Thanks.
