After the latest update I’m not be able to start any addons previously installed.
Coreelec has became very slow and when I start a video addon it stuck on loading.
Here the kodi.log when I’ve tryed to start youtube.
CoreELEC:~ # tail -100 .kodi/temp/kodi.log
2019-12-03 19:04:43.640 T:4092874736 NOTICE: EGL_VERSION = 1.4 Linux-r5p1-01rel0
2019-12-03 19:04:43.641 T:4092874736 NOTICE: EGL_VENDOR = ARM
2019-12-03 19:04:43.641 T:4092874736 NOTICE: EGL_EXTENSIONS = EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image EGL_KHR_reusable_sync EGL_KHR_fence_sync EGL_KHR_lock_surface EGL_KHR_lock_surface2 EGL_EXT_create_context_robustness EGL_ANDROID_blob_cache EGL_KHR_create_context
2019-12-03 19:04:43.641 T:4092874736 NOTICE: EGL_CLIENT_EXTENSIONS = NULL
2019-12-03 19:04:43.642 T:4092874736 NOTICE: Checking resolution 16
2019-12-03 19:04:43.643 T:4092874736 ERROR: GetString: error reading /sys/class/amhdmitx/amhdmitx0/custom_mode
2019-12-03 19:04:43.858 T:4092874736 NOTICE: GL_VENDOR = ARM
2019-12-03 19:04:43.858 T:4092874736 NOTICE: GL_RENDERER = Mali-450 MP
2019-12-03 19:04:43.858 T:4092874736 NOTICE: GL_VERSION = OpenGL ES 2.0
2019-12-03 19:04:43.858 T:4092874736 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
2019-12-03 19:04:43.858 T:4092874736 NOTICE: GL_EXTENSIONS = GL_OES_texture_npot GL_OES_vertex_array_object GL_OES_compressed_ETC1_RGB8_texture GL_EXT_compressed_ETC1_RGB8_sub_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_vertex_half_float GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_ARM_mali_program_binary GL_EXT_shader_texture_lod GL_EXT_robustness GL_OES_depth_texture_cube_map GL_KHR_debug GL_ARM_shader_framebuffer_fetch GL_ARM_shader_framebuffer_fetch_depth_stencil GL_OES_mapbuffer
2019-12-03 19:04:44.065 T:4092874736 ERROR: GetString: error reading /sys/class/amhdmitx/amhdmitx0/custom_mode
2019-12-03 19:04:44.691 T:4025475968 NOTICE: Running database version Addons27
2019-12-03 19:04:44.696 T:4025475968 NOTICE: Running database version ViewModes6
2019-12-03 19:04:44.756 T:4025475968 NOTICE: Running database version Textures13
2019-12-03 19:04:44.773 T:4025475968 NOTICE: Running database version MyMusic72
2019-12-03 19:04:44.807 T:4025475968 NOTICE: Running database version MyVideos116
2019-12-03 19:04:44.813 T:4025475968 NOTICE: Running database version TV32
2019-12-03 19:04:44.818 T:4025475968 NOTICE: Running database version Epg12
2019-12-03 19:04:44.818 T:4092874736 NOTICE: start dvd mediatype detection
2019-12-03 19:04:44.910 T:4092874736 NOTICE: load skin from: /usr/share/kodi/addons/skin.estuary (version: 2.0.26)
2019-12-03 19:04:46.036 T:4092874736 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
2019-12-03 19:04:46.130 T:4092874736 NOTICE: Register - new keyboard device registered on application->keyboard: Keyboard (0000:0000)
2019-12-03 19:04:46.131 T:4092874736 NOTICE: Register - new mouse device registered on application->mouse: Mouse (0000:0000)
2019-12-03 19:04:46.151 T:4092874736 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
2019-12-03 19:04:46.152 T:4092874736 NOTICE: Loaded playercorefactory configuration
2019-12-03 19:04:46.152 T:4092874736 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
2019-12-03 19:04:46.153 T:4092874736 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
2019-12-03 19:04:46.289 T:4092874736 NOTICE: initialize done
2019-12-03 19:04:46.289 T:4092874736 NOTICE: Running the application...
2019-12-03 19:04:46.300 T:4092874736 NOTICE: starting zeroconf publishing
2019-12-03 19:04:46.302 T:4092874736 NOTICE: CWebServer[8080]: Started
2019-12-03 19:04:46.302 T:4092874736 NOTICE: starting upnp client
2019-12-03 19:04:46.311 T:4092874736 NOTICE: starting upnp server
2019-12-03 19:04:46.321 T:4092874736 NOTICE: starting upnp controller
2019-12-03 19:04:46.322 T:4092874736 NOTICE: starting upnp renderer
2019-12-03 19:04:46.339 T:3760513920 NOTICE: ES: Starting UDP Event server on port 9777
2019-12-03 19:04:46.342 T:3760513920 NOTICE: UDP: Listening on port 9777 (ipv6 : true)
2019-12-03 19:04:46.455 T:3948245888 NOTICE: Register - new cec device registered on cec->AOCEC: CEC Adapter (0000:0000)
2019-12-03 19:04:47.641 T:3643372416 WARNING: CPlayerCoreFactory::GetPlayer(Volumio): no such player: Volumio
2019-12-03 19:04:48.391 T:3894797184 ERROR: EXCEPTION: Unknown addon id 'script.games.rom.collection.browser'.
2019-12-03 19:04:51.816 T:3869619072 NOTICE: [Amazon] Args: {}
2019-12-03 19:04:52.360 T:3869619072 NOTICE: [Amazon] AmazonDB: Service Start
2019-12-03 19:04:52.462 T:3861226368 NOTICE: [Amazon VOD] Service: Proxy bound to 127.0.0.1:48194
2019-12-03 19:04:53.739 T:3861226368 NOTICE: [Amazon VOD] Service: Proxy server started
2019-12-03 19:04:53.740 T:3861226368 NOTICE: [Amazon VOD] Service started
2019-12-03 19:04:53.773 T:3869619072 NOTICE: [Amazon] Starting DBUpdate (1970-01-01 00:00:00 / 2019-12-03 19:04:53.729666)
2019-12-03 19:04:55.879 T:3668550528 ERROR: weather.gismeteo [v.0.3.3]: Unhandled exception detected!
2019-12-03 19:04:55.880 T:3668550528 ERROR: weather.gismeteo [v.0.3.3]: *** Start diagnostic info ***
2019-12-03 19:04:55.975 T:3894797184 NOTICE: [Amazon] Args: {'sitemode': 'updateAll', 'mode': 'appfeed'}
2019-12-03 19:04:56.038 T:3668550528 ERROR: weather.gismeteo [v.0.3.3]: System info: ('Linux', 'CoreELEC', '3.14.29', '#1 SMP Wed Nov 27 06:02:54 GMT 2019', 'armv7l', '')
2019-12-03 19:04:56.039 T:3668550528 ERROR: weather.gismeteo [v.0.3.3]: OS info: Busy
2019-12-03 19:04:56.039 T:3668550528 ERROR: weather.gismeteo [v.0.3.3]: Kodi version: 18.5 Git:cf5ad23bf0c35c78e81f1ae65e47514cbd7e1aec
2019-12-03 19:04:56.040 T:3668550528 ERROR: weather.gismeteo [v.0.3.3]: File: /storage/.kodi/addons/weather.gismeteo/resources/lib/gismeteo.py
2019-12-03 19:04:56.040 T:3668550528 ERROR: weather.gismeteo [v.0.3.3]: Code context:
159:
160: while local_stamp == 0:
161:> local_stamp = calendar.timegm(time.strptime(local_date, '%Y-%m-%dT%H:%M:%S'))
162:
163: utc_stamp = local_stamp - tzone * 60
2019-12-03 19:04:56.042 T:3668550528 ERROR: weather.gismeteo [v.0.3.3]: Global variables:
Cache = <class 'resources.lib.gismeteo.Cache'>
Gismeteo = <class 'resources.lib.gismeteo.Gismeteo'>
PY3 = False
calendar = <module 'calendar' from '/usr/lib/python2.7/calendar.pyo'>
etree = <module 'xml.etree.cElementTree' from '/usr/lib/python2.7/xml/etree/cElementTree.pyo'>
iteritems = <function iteritems at 0xd77e76b0>
os = <module 'os' from '/usr/lib/python2.7/os.pyo'>
quote = <function quote at 0xd6ede370>
time = <module 'time' from '/usr/lib/python2.7/lib-dynload/time.so'>
urlopen = <function urlopen at 0xd6f3f170>
2019-12-03 19:04:56.043 T:3668550528 ERROR: weather.gismeteo [v.0.3.3]: Local variables:
local_date = '2019-12-03T17:22:00'
local_stamp = 0
self = <resources.lib.gismeteo.Gismeteo object at 0xd6836e90>
source = '2019-12-03T17:22:00'
tzone = 60
2019-12-03 19:04:56.044 T:3668550528 ERROR: weather.gismeteo [v.0.3.3]: **** End diagnostic info ****
2019-12-03 19:04:56.077 T:3668550528 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
- NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
Error Type: <type 'exceptions.ImportError'>
Error Contents: Failed to import _strptime because the import lockis held by another thread.
Traceback (most recent call last):
File "/storage/.kodi/addons/weather.gismeteo/default.py", line 699, in <module>
weather.run()
File "/storage/.kodi/addons/weather.gismeteo/resources/lib/simpleweather.py", line 51, in run
self._resolve_function()
File "/storage/.kodi/addons/weather.gismeteo/resources/lib/simpleplugin.py", line 1020, in _resolve_function
return action_callable(self._params)
File "/storage/.kodi/addons/weather.gismeteo/default.py", line 597, in forecast
data = gismeteo.forecast(location_id)
File "/storage/.kodi/addons/weather.gismeteo/resources/lib/gismeteo.py", line 339, in forecast
return self._get_forecast_info(response)
File "/storage/.kodi/addons/weather.gismeteo/resources/lib/gismeteo.py", line 199, in _get_forecast_info
'cur_time': self._get_date(xml_location.attrib['cur_time'], int(xml_location.attrib['tzone'])),
File "/storage/.kodi/addons/weather.gismeteo/resources/lib/gismeteo.py", line 161, in _get_date
ImportError: Failed to import _strptime because the import lockis held by another thread.
-->End of Python script error report<--
2019-12-03 19:04:56.400 T:3894797184 NOTICE: [Amazon] Starting DBUpdate
CoreELEC:~ #
My device is a TVBOX S905X with 1G of RAM. (It was born with Android but I’m booting CoreElec from SD card.
I know that 1 GB is low but before this update ithe system was working.
Can you give me any advice?
