AM6B+ Audio Output
Hello Everyone,
My TV (Sony) is connected via eARC to a Soundbar and with eARC enabled the TV Digital Output (Toslink) is disabled. I need to have sound via HDMI to TV, to Soundbar AND a Digital Output for my hearing impaired wife to listen via her special headphones.
Can I have both the Digital Output and the HDMI Output on the AM6B+ transmit audio at the same time? If not can you recommend an alternative method?
TIA
Hi there,
when connecting stereo earphones to “A/V out” there is no way to get any sound from my Ugoos AM6B+; only HDMI works.
May someone indicate which settings I should configure to listen from the device itself instead of TV?
Thanks in advance.
https://kodi.wiki/view/Settings/System/Audio#Audio_output_device
hi there , ive read the previous threads about the muted av output for analogue audio , in october 2026 has somebody found a fix for this , i can confirm my device amb6+ still cannot play anything thorough wired headphones . it seems a driver problem idk as the hardware is seen by linux and kodi and it reports enabled but no sounds , thank you
