Amazon Alexa Voice Remote Pro
i have a Ugoos AM6b+. Because of the locked Bootloader i am not able to use blob the function and the device is not powering on via CEC.
I dont like the original remote of the device and i dont want to keep it on always. Because of that i bought the Amazon Alexa Voice Remote Pro
Amazon Remote
connected to bluetooth it works, but its not able to switch the device on or off.
I tried to copy the remote.conf for Amazon Alexa Voice Remote Enhanced but its not working via IR.
When i disconnect the device via bluetooth there is no function via IR.
I ensured to delete the remote.conf in /flash
The Ugoos remote wasnt working too because of the changed remote.conf file.
Has someone of you also tried to use the Amazon Remote for this case?
Is it possible to get it working including powering on & off the device?
Kind regards
