baj716
20 November 2021 05:43
#1
Finally getting around to upgrading from 18.9 to 19.x on my three ODroid N2 CE boxes. I have 19.3 working with the same functionality of 18.9 on the first one except Amazon VOD addon, which won’t sign-in to Amazon. Based on the link below, it’s a TSL version issue on Amazon’s end, but need to force CE to use TSL1.0 as a work-around.
opened 04:39PM - 17 Sep 19 UTC
closed 07:51PM - 15 Nov 19 UTC
bug
primevideo
After last Widevine update days ago I wasn't able to watch any movie because of … only audio and no video was available. Then I decided to start from scratch by deleting ~/.kodi directory.
I installed only the Amazon VOD and anything else then I tried to perform login.
Issue is: no screen is presented but only the rolling wheel.
I would like to point out that until Widevine update Amazon VOD was working perfectly while after that all other plugins are still working (Netflix, RAI replay, La7 replay, etc) but Amazon VOD.
Systems where I am testing on: Debian buster / Debian stretch - Kodi 18.4 / 18.3 (from Debian multimedia repo)
log reports:
DEBUG: ------ Window Deinit (DialogAddonSettings.xml) ------ │
│2019-09-17 18:09:34.110 T:140643027732224 ERROR: [Amazon VOD] Error reason: HTTPSConnectionPool(host='na.api.amazonvideo.com', port│
│2019-09-17 18:09:34.110 T:140643027732224 INFO: CPythonInvoker(2, /home/cicero/.kodi/addons/plugin.video.amazon-test/default.py)│
│2019-09-17 18:09:36.595 T:140644758285504 DEBUG: ------ Window Deinit (Pointer.xml) ------
Further info: Plugin works properly on Mi-box S and Kodi Android (due to different Android decryption)
More log after purge kodi, delete /usr/share/kodi and ~/kodi and reinstall.
2019-09-17 19:38:19.597 T:140663072230592 NOTICE: ADDON: xbmc.addon v18.4.0 installed
2019-09-17 19:38:19.597 T:140663072230592 NOTICE: ADDON: xbmc.core v0.1.0 installed
2019-09-17 19:38:19.597 T:140663072230592 NOTICE: ADDON: xbmc.gui v5.14.0 installed
2019-09-17 19:38:19.597 T:140663072230592 NOTICE: ADDON: xbmc.json v10.3.0 installed
2019-09-17 19:38:19.597 T:140663072230592 NOTICE: ADDON: xbmc.metadata v2.1.0 installed
2019-09-17 19:38:19.597 T:140663072230592 NOTICE: ADDON: xbmc.python v2.26.0 installed
2019-09-17 19:38:19.597 T:140663072230592 NOTICE: ADDON: xbmc.webinterface v1.0.0 installed
2019-09-17 19:38:19.659 T:140663072230592 NOTICE: load skin from: /usr/share/kodi/addons/skin.estuary (version: 2.0.25)
2019-09-17 19:38:57.164 T:140661244290816 NOTICE: [Amazon VOD] Switching UserAgent
2019-09-17 19:38:57.165 T:140661244290816 NOTICE: Previous line repeats 1 times.
2019-09-17 19:38:57.165 T:140661244290816 NOTICE: [Amazon VOD] Loading list of common UserAgents
2019-09-17 19:38:57.167 T:140661244290816 NOTICE: [Amazon VOD] getURL: https://techblog.willshouse.com/2012/01/03/most-common-user-agents/
2019-09-17 19:38:57.167 T:140661219211008 NOTICE: [Amazon VOD] Loading list of common UserAgents
2019-09-17 19:38:57.170 T:140661219211008 NOTICE: [Amazon VOD] getURL: https://techblog.willshouse.com/2012/01/03/most-common-user-agents/
2019-09-17 19:39:01.077 T:140661219211008 ERROR: [Amazon VOD] Error reason: 503 error (TryAgain)
2019-09-17 19:39:01.078 T:140661219211008 NOTICE: [Amazon VOD] Attempt #2
2019-09-17 19:39:01.078 T:140661219211008 NOTICE: [Amazon VOD] getURL: https://techblog.willshouse.com/2012/01/03/most-common-user-agents/
2019-09-17 19:39:01.103 T:140661244290816 ERROR: [Amazon VOD] Error reason: 503 error (TryAgain)
2019-09-17 19:39:01.103 T:140661244290816 NOTICE: [Amazon VOD] Attempt #2
2019-09-17 19:39:01.103 T:140661244290816 NOTICE: [Amazon VOD] getURL: https://techblog.willshouse.com/2012/01/03/most-common-user-agents/
2019-09-17 19:39:05.076 T:140661244290816 ERROR: [Amazon VOD] Error reason: 503 error (TryAgain)
2019-09-17 19:39:05.077 T:140661244290816 NOTICE: [Amazon VOD] Attempt #3
2019-09-17 19:39:05.077 T:140661244290816 NOTICE: [Amazon VOD] getURL: https://techblog.willshouse.com/2012/01/03/most-common-user-agents/
2019-09-17 19:39:05.085 T:140661219211008 ERROR: [Amazon VOD] Error reason: 503 error (TryAgain)
2019-09-17 19:39:05.085 T:140661219211008 NOTICE: [Amazon VOD] Attempt #3
2019-09-17 19:39:05.085 T:140661219211008 NOTICE: [Amazon VOD] getURL: https://techblog.willshouse.com/2012/01/03/most-common-user-agents/
2019-09-17 19:39:09.082 T:140661219211008 ERROR: [Amazon VOD] Error reason: 503 error (TryAgain)
2019-09-17 19:39:09.083 T:140661219211008 NOTICE: [Amazon VOD] Using UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36
2019-09-17 19:39:09.126 T:140661244290816 ERROR: [Amazon VOD] Error reason: 503 error (TryAgain)
2019-09-17 19:39:09.133 T:140661219211008 WARNING: CPythonInvoker(2, /home/cicero/.kodi/addons/plugin.video.amazon-test/default.py): the python script "/home/cicero/.kodi/addons/plugin.video.amazon-test/default.py" has left several classes in memory that we couldn't clean up. The classes include: N9XBMCAddon9xbmcaddon5AddonE,N9XBMCAddon4xbmc7MonitorE,N9XBMCAddon7xbmcgui6DialogE
2019-09-17 19:39:09.133 T:140661244290816 NOTICE: [Amazon VOD] Using UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36
2019-09-17 19:39:09.133 T:140661244290816 NOTICE: [Amazon VOD] Retrieve territoral config
2019-09-17 19:39:09.134 T:140661244290816 NOTICE: [Amazon VOD] getURL: https://na.api.amazonvideo.com/cdp/usage/v2/GetAppStartupConfig?deviceTypeID=A28RQHJKHM2A2W&deviceID=148c5202492a035c2d008b17af2dabe1454ede2506f8398f75b93497&firmware=1&version=1&format=json
2019-09-17 19:39:09.146 T:140661252683520 ERROR: GetDirectory - Error getting plugin://plugin.video.amazon-test/
2019-09-17 19:39:10.745 T:140661244290816 ERROR: [Amazon VOD] Error reason: HTTPSConnectionPool(host='na.api.amazonvideo.com', port=443): Max retries exceeded with url: /cdp/usage/v2/GetAppStartupConfig?deviceTypeID=A28RQHJKHM2A2W&deviceID=148c5202492a035c2d008b17af2dabe1454ede2506f8398f75b93497&firmware=1&version=1&format=json (Caused by SSLError(SSLError("bad handshake: Error([('SSL routines', 'ssl_choose_client_version', 'unsupported protocol')],)",),)) (SSLError)
2019-09-17 19:39:10.786 T:140661244290816 WARNING: CPythonInvoker(3, /home/cicero/.kodi/addons/plugin.video.amazon-test/default.py): the python script "/home/cicero/.kodi/addons/plugin.video.amazon-test/default.py" has left several classes in memory that we couldn't clean up. The classes include: N9XBMCAddon4xbmc7MonitorE,N9XBMCAddon7xbmcgui6DialogE,N9XBMCAddon9xbmcaddon5AddonE
2019-09-17 19:39:20.316 T:140663072230592 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.amazon-test/) failed
2019-09-17 19:39:20.926 T:140662024419072 NOTICE: [Amazon VOD] Retrieve territoral config
2019-09-17 19:39:20.927 T:140662024419072 NOTICE: [Amazon VOD] getURL: https://na.api.amazonvideo.com/cdp/usage/v2/GetAppStartupConfig?deviceTypeID=A28RQHJKHM2A2W&deviceID=148c5202492a035c2d008b17af2dabe1454ede2506f8398f75b93497&firmware=1&version=1&format=json
2019-09-17 19:39:21.316 T:140662024419072 ERROR: [Amazon VOD] Error reason: HTTPSConnectionPool(host='na.api.amazonvideo.com', port=443): Max retries exceeded with url: /cdp/usage/v2/GetAppStartupConfig?deviceTypeID=A28RQHJKHM2A2W&deviceID=148c5202492a035c2d008b17af2dabe1454ede2506f8398f75b93497&firmware=1&version=1&format=json (Caused by SSLError(SSLError("bad handshake: Error([('SSL routines', 'ssl_choose_client_version', 'unsupported protocol')],)",),)) (SSLError)
2019-09-17 19:39:21.361 T:140662024419072 WARNING: CPythonInvoker(4, /home/cicero/.kodi/addons/plugin.video.amazon-test/default.py): the python script "/home/cicero/.kodi/addons/plugin.video.amazon-test/default.py" has left several classes in memory that we couldn't clean up. The classes include: N9XBMCAddon9xbmcaddon5AddonE,N9XBMCAddon4xbmc7MonitorE,N9XBMCAddon7xbmcgui6DialogE
2019-09-17 19:39:40.189 T:140662385145600 NOTICE: [Amazon VOD] Retrieve territoral config
2019-09-17 19:39:40.191 T:140662385145600 NOTICE: [Amazon VOD] getURL: https://na.api.amazonvideo.com/cdp/usage/v2/GetAppStartupConfig?deviceTypeID=A28RQHJKHM2A2W&deviceID=148c5202492a035c2d008b17af2dabe1454ede2506f8398f75b93497&firmware=1&version=1&format=json
2019-09-17 19:39:40.490 T:140662385145600 ERROR: [Amazon VOD] Error reason: HTTPSConnectionPool(host='na.api.amazonvideo.com', port=443): Max retries exceeded with url: /cdp/usage/v2/GetAppStartupConfig?deviceTypeID=A28RQHJKHM2A2W&deviceID=148c5202492a035c2d008b17af2dabe1454ede2506f8398f75b93497&firmware=1&version=1&format=json (Caused by SSLError(SSLError("bad handshake: Error([('SSL routines', 'ssl_choose_client_version', 'unsupported protocol')],)",),)) (SSLError)
2019-09-17 19:40:52.554 T:140663047026432 NOTICE: PulseAudio: Opened device Default in pcm mode with Buffersize 150 ms
2019-09-17 19:40:52.578 T:140662385145600 WARNING: CPythonInvoker(5, /home/cicero/.kodi/addons/plugin.video.amazon-test/default.py): the python script "/home/cicero/.kodi/addons/plugin.video.amazon-test/default.py" has left several classes in memory that we couldn't clean up. The classes include: N9XBMCAddon7xbmcgui6DialogE,N9XBMCAddon9xbmcaddon5AddonE,N9XBMCAddon4xbmc7MonitorE
2019-09-17 19:40:52.578 T:140661638551296 ERROR: GetDirectory - Error getting plugin://plugin.video.amazon-test/
2019-09-17 19:40:52.582 T:140663072230592 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.amazon-test/) failed
2019-09-17 19:40:57.960 T:140663072230592 NOTICE: Stopping player
2019-09-17 19:40:57.960 T:140663072230592 NOTICE: Storing total System Uptime
2019-09-17 19:40:57.960 T:140663072230592 NOTICE: Saving settings
2019-09-17 19:40:57.962 T:140663072230592 NOTICE: Saving skin settings
2019-09-17 19:40:57.963 T:140663072230592 NOTICE: Stopping all
2019-09-17 19:40:57.963 T:140663072230592 NOTICE: ES: Stopping event server
2019-09-17 19:40:57.963 T:140663072230592 NOTICE: stopping zeroconf publishing
2019-09-17 19:40:58.356 T:140661655336704 NOTICE: ES: UDP Event server stopped
2019-09-17 19:40:58.360 T:140663072230592 NOTICE: stop dvd detect media
2019-09-17 19:40:58.789 T:140661227603712 NOTICE: [Amazon VOD] Service: Proxy server stopped
2019-09-17 19:40:58.789 T:140661227603712 NOTICE: [Amazon VOD] Service stopped
2019-09-17 19:40:58.794 T:140661227603712 WARNING: CPythonInvoker(1, /home/cicero/.kodi/addons/plugin.video.amazon-test/service.py): the python script "/home/cicero/.kodi/addons/plugin.video.amazon-test/service.py" has left several classes in memory that we couldn't clean up. The classes include: N9XBMCAddon9xbmcaddon5AddonE,N9XBMCAddon4xbmc7MonitorE,N9XBMCAddon7xbmcgui6DialogE
2019-09-17 19:40:59.015 T:140663072230592 NOTICE: Application stopped
2019-09-17 19:40:59.216 T:140663072230592 NOTICE: XBApplicationEx: destroying...
2019-09-17 19:40:59.583 T:140663072230592 NOTICE: unload skin
2019-09-17 19:40:59.605 T:140663072230592 NOTICE: unload sections
2019-09-17 19:40:59.637 T:140663072230592 NOTICE: XBApplicationEx: application stopped!
The fix is to edit /etc/ssl/openssl.cnf, but that file doesn’t exist on my CE 19.3.
Any idea where these TSL settings live on CE 19.3?
Thx,
-Brad
system
closed
19 February 2022 11:43
#2
