Hi,I have an Amlogic A311D Android device with the original firmware being Android 9.0. I use coreelec 20.2 to play 4K HDR10+videos, but the screen is black with only sound, however both the image and sound were normal when I played the same video using coreelec 19.4_RC1(or other older versions).This is so confusing for me,any suggestions?
more your TV does not like the frame rate switching to 1080p59.94hz when you play your h265 video.
You boot in 1080p60hz and when it’s working it might does not like the frame rate frac rate.
Enable only 1080p60hz in white list and try again.
just set 1080p60hz in white list,but no effect ,HDR10+ playback still black screen with only sound.Why the same device running ce19.4_RC1(kernel 4.9.113) can play normally?
