Thanks wiil try this!
Do you have a screenshot for what is working?
Can you make this change and write it here for default Estuary skin, as you did for Leia?
Here is one for Arctic Horizon (Matrix) if any one needs it.
DialogPlayerProcessInfo.xml (10.1 KB)
Uploaded a new xml. Was trying to only show the info on my android boxes, but apparently that wasn’t working. Should look like this:
edit: 3rd version attached above. Only shows amlogic info on amlogic devices and not on i.e. Kodi for Windows.
No need, default Estuary skin in Matrix already has the changes.
thank you very much! will try this!
Hi i just tried it and with live tv in the backend section the first line there’s something wrong.
See my screenshot.
I don’t have a PVR backend, so I can’t test it but you can. On line 175 you need to increase the value in 230, maybe try 300.
Will try that thanks!
Is it possible to make the overlay smaller?
So not fullscreen like it is now.
change line 9 to <height>760</height>
Could be a different number for you since you’re changing the tvheadend part, but 610 seems to work for me.
What did you change for the PVR part? So I can inorporate that as well in my file.
I’ll have to look when i’m home @work roght now. But out of my head it i increased line 175 to 370.
But i’ll let you know.
@raytestrak just checked it for you and i changed line 175 to 370.
And for the overlay i changed line 9 to 775
I attached my xml file here.
DialogPlayerProcessInfo.xml (13.5 KB)
Your file:DialogPlayerProcessInfo.xml
Will serve for version 9.27 with default skin, I would like to know the temperature of my x96 max 905x2, I am new but I already found where to replace the file.
Please can you point out where I can find files that will work for my x96. max with coreelec 9.27
Hi, in this post can you see that for Leia… Processinfo leia
Muchas Thank you very much, I will try it, in the mobile I was looking for where the file is located and I found it, then I will look at coreelec, I like to be able to see the temperature and the cpu load and other information.
What is Estuary “V2” ? Is this skin.estuary.modv2 Version:3.0.9+matrix (Matrix) by Guilouz is good one with your DialogProcessInfo.xml ?
