Yes it’ there, and it’s enabled…
Really not sure why it’s not working then. What’s displayed on the screen when when you bring up the player process info box can you post a quick picture?
It’ the same as without your script. Sending you Kodi log, there are some errors but I think they are not related.kodi.zip (5.8 KB)
Honestly I think this is soo cool that we can patch estuary in CoreELEC and add this. So it is default for everyone.
Yes, please do, but make shure it works. As you see I cannot get it to work even with his Estuary version
It works here.
With your MOD skin, or with his version ?
With his version. Just install both zips. The skin name is different right!?
Yes, and I did that, but no result…
Btw, which addon did you install, verson posted here, or from Github, because they are different.
Lemme guess you installed my recent Amlogic-ng build
No, installed on 10th April version.
Let me explain in this build are new patches from @cdu13a and there are no strings for the modes in /sys/class/amhdmitx/amhdmitx0/config
Well then I don’t know. Probably it’s only in one of the cscd testbuilds I’m using.
I did not try it on ng version.
Can you
cat /sys/class/amhdmitx/amhdmitx0/config
CoreELEC (official): devel-1554893566 (Amlogic.arm)
CoreELEC:~ # cat /sys/class/amhdmitx/amhdmitx0/config
cur_VIC: 16
cur_video_param->VIC=16
cd = 4
cs = 2
audio config: on
audio on/off: on
audio source: SPDIF
audio type: L-PCM
audio channel num: 2 channels
audio sample rate: 44.1kHz
audio sample size: MAX
3D config: off
CoreELEC:~ #
Yeah this will not work
On which version will it, then ?
