Hi all!
A few days ago I updated my Minix U22-XJ from CE-NG 21.3 to CE-NO 22.0 beta 2.
Transition was smooth, including installing to eMMC. The only thing I have found not to work is Wake-on-Lan (WoL).
On the CE config addon, it can’t be turned on:
The only recent reference I have found to WoL not working was on @vpeter reply on this Minix U8K thread:
I am unsure if that comment was specific of Minix U8K or CE-NO more generally.
Anyone successfully using WoL on CE-NO?
On Coreelec-NO, I have the problem on an AM6b+ connected to a LG E6, in TV-Led mode, PPI always states that DV video is being converted to DV, which is not true (TV reports DV, and I can see it is correct).
CoreELEC:~ # cat /sys/class/amhdmitx/amhdmitx0/config
VIC: 93 3840x2160p24hz
Colour depth: 8-bit
Colourspace: RGB
Colour range: full
EOTF: SDR
YCC colour range: limited
Colourimetry: BT.2020nc
Note that SDR + BT.2020nc is an oxymoron, as that combination should not be able to exist. This is new behaviour compared to Kodi 21 builds. This behaviour also bleeds into ppi GUI and plugins (Such as TinyPPI). It is probably confused by the 8bit RGB tunnel. Hope it can be fixed in future builds.
Is the new kernel version 6.12?
Android 16, 6.12.69, but no dovi.ko available yet.
suppose, we have dovi.ko avaipable for 6.12 kernel.
what would be advantage to use kernel 6.12 against kernel 5.4??
Yep, would be nice, maybe one homatics box 4k plus v3… for that.
and https://www.androidtv-guide.com/streaming-gaming/rocktek-g2-next/
